Sep 15th, 2026, 5:15pm
Any software for viewing  old design data ? (Read 4297 times)
AnalogAroma
Nov 05th, 2007, 11:26am
H Everybody,
        Nowadays if I want to see my   design works in old chip design projects, I need to install the project-specific design kit again as Cadence does not
support multiple processes at the same time.   This is quite annoying and  on several occasions I need to re-invent the wheel .
Do you know any software that will store all the design data of a finished project  and enable us to look into old designs easily ?
With Regards,
        Analog Aroma
Paul
Switzerland
Re: Any software for viewing  old design data
Reply #1 - Dec 3rd, 2007, 12:58pm
You'll have to back up your Cadence version with the design kit and the design data... A good alternative is called "documentation"  ;)
Paul
smcbutler
Bay Area
Re: Any software for viewing  old design data ?
Reply #2 - Jan 31st, 2008, 10:39pm
AnalogAroma wrote on Nov 5th, 2007, 11:26am:
H Everybody,
With Regards,
        Analog Aroma
Perhaps you need a design data management tool? One tool optimized for
analog designers is VersIC by MethodICs.
This is tightly integrated into Cadence DFII, Virtuoso, Composer, and ADE. It
uses as its backend database a choice of Perforce or Subversion.
www.methodics-eda.com
Christoph M
Reply #3 - Jun 30th, 2008, 2:57pm
Paul wrote on Dec 3rd, 2007, 12:58pm:
Paul
Now what do you do if you can get access to the Cadence design (DFWII) files, but don't own Cadence?
Is there any way to get access to Cadence on a temporary basis, mainly just to look at old designs and export some documentation (e.g., schematic printouts)?
How painful (both in terms of setting up design kits and $$$) would that be?
Christoph M
achim.graupner
Reply #4 - Aug 14th, 2008, 9:41pm
My dear,
if you just want so view schematics it might be helpful to copy the Primitive-Library into the working directory and remove everything from it besides the symbol views (using command line, especially care any .il-files, they may interfere with the PDK).
Everything else is complicated indeed.
Achim
Achim Graupner
ZMD AG, Dresden, Silicon Saxony, Germany
