Aug 15th, 2024, 10:51am
VerilogA erases clock phase noise with PNOISE (Read 4519 times)
adam_eaz
Nov 06th, 2007, 10:06am
I am applying a differential clock signal as an input which has some phase noise, and I am producing a differential clock signal that has a fixed pulse width.  The problem is that the resulting signal doesn't have any phase noise.  The PSS analysis does work, with the correct wave forms produced.
`include "constants.vams"
`include "disciplines.vams"
module xosc10b_amfilter (inp, inm, outp, outm);
input inm, inp;
inout outm, outp;
voltage inm, inp, outp, outm, vgain;
parameter real vswing=1;
parameter real td=50p;
parameter real tt=50p;
parameter real delaytime=6.4300412n;
real vtime, vmin, vmax;
integer actNow, out, reset;
analog
begin
  actNow=0;
  vmin=-vswing/2;
  vmax=vswing/2;
  @(cross(V(inp,inm),1)) actNow=1;
  vtime= idt(1/delaytime, 0, actNow);
  out  = vtime<1;
  V(outp,outm) <+ transition(out ? vmax : vmin, td, tt);
Stefan
Re: VerilogA erases clock phase noise with PNOISE
Reply #1 - Nov 6th, 2007, 10:17am
You should (dramatically!) increase your analog accuracy-settings and specify the tolerance of the @cross statement.
td and tt are far too high with 50 ps. This would kill nearly all phasenoise characteristics.
Just think about an oscillator with a center frequency of  2.4GHz for Bluetooth for example.
Specifications for the LO demand for -105 dBc/Hz at 1 Mhz offset from the carrier which leads to a corresponding Jitter (standard deviation) of around 48 fs.
It's for sure that an accuracy of several ps simply swallows this noise ...
View Profile 16731287   IP Logged
adam_eaz
Reply #2 - Nov 6th, 2007, 11:50am
I tried your suggestion of increasing the analog accuracy and cross point.  I also changed the rise time to 200ps, but I am still getting the same result which is -6.4k dBc for all frequencies.  Any other suggestions?
Adam
Stefan
Reply #3 - Nov 6th, 2007, 1:35pm
You should tighten the rise time, not raising it.
It might be best to provide the whole setup, including the model for the noisy osc.
I might be able to check it tomorrow morning (local time central europe).
Stefan
Frank Wiedmann
Munich, Germany
Reply #4 - Nov 6th, 2007, 11:29pm
