Aug 16th, 2024, 11:24pm
thd of buffer post DAC (Read 2184 times)
cmos_cowboy
Nov 07th, 2007, 2:30pm
I have a DAC that is designed to give 10bit accuracy.
It requires a unity gain buffer to drive a capacitive load.
If I do not want the buffer to degrade the DAC output by more
than say 0.5 lsb I am correct in assuming that -
0.5/1024 gives rise to a THD spec of -66dB.
Am I correct in my assumptions or is it a little more complicated?
cktlife
Re: thd of buffer post DAC
Reply #1 - Nov 8th, 2007, 12:38am
I have the same question for the cascaded system. In this case, two blocks are in series, DAC+buffer. Suppose that the overall 10-bit accuracy is wanted, how do i allocate the linearity requirement for each block? Is there any analytical solution or just emperical estimation?
Berti
Reply #2 - Nov 8th, 2007, 10:51pm
Hi everybody,
how to calculate the linearity of cascaded systems can be found in text-books (similar to Friis' formula).
In case of a DAC+buffer combination I think the question is whether you want the linearity limited by
the DAC, the buffer or a combination of both.
Usually the liniearity should be limited by the DAC. The buffer should therefore be linear enough not to
degrade the overall linearity to much.
