Aug 17th, 2024, 1:16am
vbic HBT rth & cth conversion SpectreRF to HSPICE (Read 3269 times)
imtired
Santa Rosa
Nov 12th, 2007, 12:05pm
HI all,
I am in need of some help converting VBIC HBT parameter units for the self-heating thermal resistance and capacitance "rth" and "cth" from SpectreRF to HSPICE.  I found that the untis in SPectreRF for these two parameters are ohms and Farads, respectively, but in HSPICE the units are in K/W and J/K.  Does anyone know how to do this?
RU
Re: vbic HBT rth & cth conversion SpectreRF to HSP
Reply #1 - Nov 12th, 2007, 1:04pm
I think the HSpice units are correct, and the Spectre folks are perhaps a little sloppy.  You shouldn't need any conversion.
"rth" is implemented as a resistor (in terms of its matrix stamp), but the "current" that flows through it is heat (power) and the "voltage" across it is really temperature (in Kelvin).
imtired
Santa Rosa
Reply #2 - Nov 12th, 2007, 6:24pm
So it was just a matter of describing the units in different domains, HSpice in thermal domain, and SpectreRF in the electrical domain.
That makes more sense to me now, and so I don't need to do any conversion of the parameters Rth and Cth.
Thanks Geoffrey.
