Quote:I am trying to design a sigma delta modulator for a fractional PLL.
I plan on using a 3rd order modulator, with multi-bit quantizer.
The architecture I would like to use is 'multiple feed forward', which seems to be common in fractional pll's.
The one thing I am not sure of is how to calculate the stable input range of the modulator.
Is it dependent on the number of bits in the quantizer, or the NTF, or both?
If your multi-bit quantizer is more than 4bits, a stability is almost determined by NTF.
Quote:Is there good literature I can use to learn about this? Thanks in advance.
Following is a good book as introduction.
http://www.designers-guide.org/Books/#Schreier-2004
