Jul 16th, 2024, 10:46am
A wield problem in behavior model simulation (Read 4212 times)
jimwest
Nov 15th, 2007, 6:16pm
I built a gated pll for CDR in serdes.
Every block was implemented in verilog-a. And the structure is shown in Fig.1.
When the gated vco was disabled, everything is ok. The control voltage which is highlighted in Fig.1 is shown in Fig2.
At the moment when the gated vco was enabled while the pll locked, there is a bump in control voltage and the pll will be locked at another freq as shown in Fig3.
I just wonder What introduces this wield step in control voltage.
And I tried to use different method and different simulator this bump can not be eliminated.
jimwest
Re: A wield problem in behavior model simulation
Reply #1 - Nov 15th, 2007, 6:19pm
Fig2
jimwest
Reply #2 - Nov 15th, 2007, 6:22pm
Fig.3
Stefan
Reply #3 - Nov 16th, 2007, 12:32am
The schematic is hard to understand, especially because you didn't label any of the signals.
The only thing I'm wondering about at first sight is that you're missing a clearly defined VDD node.
View Profile 16731287   IP Logged
Stefan
Reply #4 - Nov 16th, 2007, 12:34am
and another thing ... maybe you should try to use a vcvs to couple the second oscillator to the control voltage. Maybe it's just some sort of current source problem coming from the CP/LF ?
jimwest
Reply #5 - Nov 16th, 2007, 9:23pm
The vcvs has been used to isolate the gated vco and pll, but this bump is still there.
I skip the dc analyze when do the transient simulation, so no VDD should be set.
