Aug 17th, 2024, 3:16am
Sigma-Delta Mod: Spurious tone (Read 3521 times)
neoflash
Mixed-Signal
Designer
Nov 17th, 2007, 2:06am
In text book from Temes, 2nd order modulator suffer non-linearity from quantizer and thus contains tone in spectrum.
Why 1st order modulator does not suffer same problem and looks spur free?
Berti
Re: Sigma-Delta Mod: Spurious tone
Reply #1 - Nov 18th, 2007, 10:32pm
Hi Neoflash,
which text book are you referring to? Which chapter?
Because I think you are confusing different issues. I guess what you mean are idle tones, which might
be a problem in single-bit low-order (1st&2nd order) modulator.
Please post the full reference of the text book to clarify the question.
neoflash
Mixed-Signal
Designer
Reply #2 - Nov 19th, 2007, 6:04am
Book named: Delta-Sigma Data Converters. by Temes and Schreier
In figure 3.6, we see MOD2 contains spurious tone which does not appear in fig2.20 for mod1.
Berti
Reply #3 - Nov 20th, 2007, 12:01am
the name of the book is "UNDERSTANDING delta-sigma data converters". I think the difference is that in fig 3.6 the spectrum is shown using averaging
(uncorrelated noise is reduced and the tones are better visible), while in fig. 2.20 no averaging is used and it is therefore hard to distiguish
between noise and tones.
But in general a first-order modulator is worse than second-order in terms of tonal behavior.
neoflash
Mixed-Signal
Designer
Reply #4 - Nov 20th, 2007, 5:45am
Oh, that's good to learn about it. Author emphasized tones in 2nd order MOD, so it is a bit confusing.
Thanks for this clarification.
