vivkr
Hi Jerry,
Thanks for your comment. However, the problem is not really solved this way. If I don't design the clamp correctly, then I may see no improvement in performance or even worsening. So, this question cannot be answered unless I have a good working clamp, and if I had that, I wouldn't be asking the question.
Is there a good design guideline or some particular fact to keep in mind when inserting the clamps? I just did some rough calculations treating the clamp device as if it would be a diode. The body effect was something I took a look at as well. However, I don't know if there is anything else to watch out for. I am not using very fine line technology, and the amp is fully diff. so that I don't really expect a drastic cutoff on the devices.
Any comments?
Regards Vivek
