Hi didac,
here's the link for the thesis.
http://www.eecs.berkeley.edu/Pubs/TechRpts/2007/EECS-2007-57.htmlAs far as I know, there was no antenna in the design. Furthermore, there was no input band-select filter. However, if you read the section on mixer input impedance, he talks about how the input impedance forms a bandpass response which can be used to effectively cancel out of band interferrers. That was his justification for having no band-select filter. However, I don't think this effect was thoroughly researched. One more point to note is that antennas themselves have their own S11, and i believe that the actual antenna input impedance can be vastly different from 50 ohm. Since the Cook matching network relies on a 50 ohm source, I think it is a bit risky.
I should also point out that his analyses do not follow his implementation. For example, i don't have the paper on hand, but i think he showed simulations of the mixer input impedance with RSW=100 ohm, where the input impedance was around 5 kohm. However, in his implementation, RSW=5 ohm which leads to much lower input impedance (less than 1 kohm). The mixer input impedance is the basis for the high voltage gain of the input matching network. As a matter of fact, I don't think i agree with his calculations of mixer input impedance either. Perhaps you can verify them. It seems very strange to me that the input resistance depends on the source resistance.
Anyway I've read the paper several times now so I guess i could go on forever.
Hope you recover your google powers
![Smiley Smiley](https://designers-guide.org/forum/Templates/Forum/default/smiley.gif)
cheers,
Aaron
