Jul 22nd, 2024, 10:27am
Proper gounding for wafer probing. (Read 3678 times)
HFG
Nov 22nd, 2007, 2:55pm
I have access to a GGB wafer wedge that holds 2 GSG probes and 4 DC probes. Iam trying to maximize the number of connections i can use and was wondering if i can use the grounds from the RF probes for my circuit ground or if i have to use one of the 4 DC probes.
Stefan
Re: Proper gounding for wafer probing.
Reply #1 - Nov 23rd, 2007, 1:07am
You can use the G from GSG for ground -
IF
- you don't care about ESD structures (remember that normally you should contact ground & VDD for ESD first, before connecting signals ...)
- your probe is able to carry enough dc current that might be used by the chip.
View Profile 16731287   IP Logged
HFG
Reply #2 - Nov 23rd, 2007, 1:08pm
Thanks for the reply, thats pretty much what i figured. I can't seem to find one source that contains all the information about probing. I can't find little bit of information here and there.
