Sep 28th, 2024, 11:17pm
The scale down factor (Read 2289 times)
jimwest
Nov 25th, 2007, 11:17pm
I'm preparing for a project proposal about Giga ethernet PHY.
I have to estimate a area shrink factor, from the 0.13 to 65nm cmos process.
I don't have the experience in 65nm, so could you guys give me some hits.
Thanx!!
B/R,
Jim
ACWWong
Oxford, UK
Re: The scale down factor
Reply #1 - Nov 28th, 2007, 3:41am
digital synthesized cell "should" reduce by factor 4 due to factor 2 reduction in channel length, but this might not be the case for your techonlogy due to the back-end (metals, vias etc.) not scaling effectively. A good way to estimate is to compare the area of a standard cell (e.g a NAND or flip-flip) between 0.13u and 65nm...
of course "analog" circuits won't shrink that much, especially if using spiral inductors or other passives...
jimwest
Reply #2 - Nov 28th, 2007, 7:10pm
If the area is not that directly related to the process for analog, then how about the power consumption?
Suppose that
case 1 the supply voltage doesn't change, how about the power consumption for the 65nm process?
case 2 the supply voltage reduced, how about the power consumption for 65nm process?
B/R,
Jim
