Aug 17th, 2024, 7:17am
Phase Noise/ Jitter for PLL (Read 1741 times)
asako
Nov 26th, 2007, 5:23pm
I set up a PLL with verilogA function blocks as described in Mr. Kundert report.
Now, PLL converges, but when I plot phase noise using the Matlab code from the report,
I saw a huge degradation compared to single VCO or clock simulation result.
Then, I notice that the Mr. Kundert report also  shows same effect; VCO's phase noise is -110dB/Hz@100KHz from Spectre RF, however, phase noise calculated in Matlab code is around -40dB/Hz.
How should I comprehend this ? Is there any good way to set convergence/accuracy setting ?
