Jul 16th, 2024, 6:44pm
question about input referred noise (Read 6431 times)
Julian18
Nov 29th, 2007, 6:51pm
Hi,  there:
     suppose I have a circuit, and I do three simulations as described below
1)  add a port as input probe, set its resistance, say 50 , and run noise analysis, now I can get input referred noise voltage from the result, call it NP.
2)  replace the port with a voltage source in series with a 50Ohms resistor, run noise analysis, get the input referred noise voltage ,call it NV.
3)  replace the voltage and series resistor with a current source in parallel with a 50Ohms resistor, run noise analysis, get the input referred noise current, call it NI.
 Now can any one tell me what's the relationship btw these three quantities.
Thanks.
aaron_do
Re: question about input referred noise
Reply #1 - Nov 30th, 2007, 1:45am
input referred noise is just the output noise power divided by the power gain. If you measure the output noise is V^2/Hz, and you want to refer it back to a voltage, divide by (V/V)^2. If you measure in terms of output current ^2 then divide by gm^2. Your 50 ohm resistor is just complicating things since you don't need it to find the input referred noise (unless its part of the circuit). In fact you have to subtract its noise contribution to find the input referred noise. For example, if you have a port and you measure NF, the IRN can be found from,
NF=(IRN+kT50)/kT50
where IRN is in V^2/sqrt(Hz)
hope it helps,
Aaron
Julian18
Reply #2 - Nov 30th, 2007, 4:28am
aaron_do wrote on Nov 30th, 2007, 1:45am:
NF=(IRN+kT50)/kT50
hope it helps,
Aaron
Hi, Aaron:
    thank your for your information.the reason of adding the resistor is that, I just want to see the relationship of these three quantities, as spectre reference sais, when input port is used as input probe, the noise associated with the port resistance will contribute to the total output noise, so I intentionally add resistors in two other situations to equate the noise source number in the circuit.  and i expect that if we ignore the correlation btw the  noise voltage and noise current, the following relation may hold:
                 N_current^2*50^2+N_voltage^2 = N_port^2
but i can not arrive at this relation from the simulation result. So I asked the question.
Any other information?
didac
There's a million
ways to see the
things in life
manresa,spain
Reply #3 - Nov 30th, 2007, 5:21am
Have you checked that both port & simulator temperatures are the same?
Hope it helps,
