Aug 17th, 2024, 1:14pm
How to test the AD in GPS chips (Read 2217 times)
edward.yin
CHN
Dec 12th, 2007, 12:15am
Hi, in GPS chips, there is a 2 bit ADC to digitize the IF output and give MAG&SIGN output to the baseband part.
Then I see in Zarlink datasheets a clock is used to synchronize the MAG & SGIN to latched to the rising edge of the clk.
But, they use a 5.714M clk to latch a 4.309M signal when in theory the digital output should faithfully track the original IF signal and have a certain duty cykle about 30%.
I think for sampling it is impossible.
So here how do the ADC work?
And how to test whether the ADC works well?
Thanks!
View Profile edward.yin   IP Logged
Berti
Re: How to test the AD in GPS chips
Reply #1 - Dec 12th, 2007, 11:38pm
Sounds like sample rate conversion (SRC) is performed.
Reply #2 - Dec 13th, 2007, 12:08am
Hi Edward,
Do you mean that the sampling rate is 4.309MHz?
Yawei
