edward.yin
CHN
Hi, in GPS chips, there is a 2 bit ADC to digitize the IF output and give MAG&SIGN output to the baseband part. Then I see in Zarlink datasheets a clock is used to synchronize the MAG & SGIN to latched to the rising edge of the clk. But, they use a 5.714M clk to latch a 4.309M signal when in theory the digital output should faithfully track the original IF signal and have a certain duty cykle about 30%. I think for sampling it is impossible. So here how do the ADC work? And how to test whether the ADC works well? Thanks!
