Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 5
th
, 2024, 5:26pm
Home
Help
Search
Login
Register
PM to admin
Simulators
RF Simulators
› VCO + tone on varactor PSS sim
Previous topic
Next topic
VCO + tone on varactor PSS sim (Read 1814 times)
borisk
Dec 13
th
, 2007, 3:33pm
Does anyone have insight into how a VCO with a periodic signal on the control voltage would be simulated with PSS? The expected spectrum is the vco tone with sidebands on either side at the offset corresponding to the frequency of the varactor control voltage signal.
Clearly, TRAN and then FFT is one way of doing it, but can it all the done with PSS/QPSS?
Thanks for your help.
Cheers,
Boris
IP Logged
jlee
Re: VCO + tone on varactor PSS sim
Reply #1 -
Dec 23
rd
, 2007, 7:01pm
Try to add a noise file included in vdc, make a spur-like noise shape at some offset frequency as you want, run PSS+Pnoise, and you will see the spurious tone in the phase noise curve.
Hope it can help u.
Jason Lee
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
»» RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
