Jason,
In answer to Question 2, hopefully, I will get the nomenclature correct:-)
When plotting L{jw}, the spot noise power of the output voltage, the power of the phase noise can not exceed the power of the carrier, so at low frequency the spot noise power, L{jw}, flattens out. The saturation frequency is the frequency at which the L{jw} stops increasing. Since the area are under the curve is always unity, that is, L{jw} is normalized to the carrier power, the lower the phase noise is the lower the value of the saturation frequency is.
