Jul 19th, 2024, 12:19am
How to setup Spectre V62 (MMSIM62) for IC5141 ! (Read 2848 times)
cuonghpm
Dec 15th, 2007, 3:16pm
Hi All,
I am using the cadence ic5141 and now I want to use Spectre V62 (from MMSIM62) with cadence IC5141. I have already installed MMSIM62 onto the server but I don't know how to make it work with ic5141. After installing MMSIM62, I run icfb then the old spectre (5141) is still there.
Please help me.
I appreciate for your help and look forward to hearing form you.
Andrew Plumb
Ottawa, Ontario, Canada
Re: How to setup Spectre V62 (MMSIM62) for IC5141
Reply #1 - Dec 16th, 2007, 7:17pm
Just make sure the path to MMSIM62 spectre comes before the path to IC5141 in your $PATH.
cuonghpm
Reply #2 - Dec 21st, 2007, 6:51pm
Thanks so much, Andrew.
