Aug 15th, 2024, 6:21pm
LNA input impedance (Read 5233 times)
nxing
God help the person
who help themselves
China
LNA input impedance
Dec 18th, 2007, 11:54am
Hello everybody,
I have a CMOS LNA and the topology is the classic cascode architecture with inductor degeneration at source of input device. what I find is that I can see a negative Z11 (real part) after the S-parameter analysis. Have anybody met the same problem? how come the real part become the negative? what's the physical meaning?
Thanks !
BTW, this is with 65nm technology.
nxing
didac
There's a million
ways to see the
things in life
manresa,spain
Re: LNA input impedance
Reply #1 - Dec 19th, 2007, 3:01am
Hi nxing,
I think that the problem arises from the parasitic capacitance (maybe csb) that contributes as a negative real part in the input impedance. I think that you will need to increase the value of the degeneration inductance to compensate it or you maybe will face an unstability problem.
Hope it helps,
nxing
God help the person
who help themselves
China
Reply #2 - Dec 19th, 2007, 11:28am
Hi Didac,
Thanks for the reply. Actually, what I found is that the Cgs of this technology is very small. So what I do is to put a C parallel with Cgs to slow it down. I didn't see other people use this technique. So far the simulation goes quite well, just not sure there are any drawback for this design or any potential problem.
nxing
didac
There's a million
ways to see the
things in life
manresa,spain
Reply #3 - Dec 20th, 2007, 12:56am
Hi nxing,
I've seen this technique before,in fact we had a LNA manufactured and measured with this C, but we didn't encounter any negative impedance problem. Have you checked the two stability factors, not only in your band of interest but for a wide bandwidth?
Hope it helps,
noiseless
Reply #4 - Feb 25th, 2008, 9:50pm
I encounted the same thing. The s11 is within the unit circle, however, real part of Z11 is negative. How it comes? anyone can give explain?
Frank Wiedmann
Munich, Germany
Reply #5 - Feb 26th, 2008, 12:24am
S11 corresponds to the input impedance when the other port(s) is/are terminated with the reference impedance (usually 50 Ω). Z11 is the input impedance when the other port(s) is/are open.
northfish
Reply #6 - Apr 7th, 2008, 2:28pm
I think adding an extra capacitor in parallel with Cgs would decrease your LNA gain, since the Q of the input network is decreased.
By the way, I don't quite understand why the real part of the Z11 could be negative.  My thinking is that probably you got a small capacitance in series with Ls, and at the operating frequency the small cap negated out your degeneration inductance and made the real part of Z11 negative.
northfish
