Aug 15th, 2024, 4:33pm
Is Phase Noise (VCO) affected by amplifier ? (Read 2011 times)
Faisal
Apr 07th, 2008, 11:53am
Is the Phase Noise (VCO) specified in terms of dbC/ Hz affected by the amplifier that follows it ? The amplifier contribuites noise i.e. has noise figure > 0.
I am confused about the overall phase noise  i.e. cascasde of VCO and buffer amplifier...
Any links / references and explanation will be certainly helpful
neoflash
Mixed-Signal
Designer
Re: Is Phase Noise (VCO) affected by amplifier ?
Reply #1 - Apr 8th, 2008, 5:03am
voltage noise is different from timing noise (jitter). So, the noise of the buffer amplifier is converted to timing jitter in the way of modulating the zero-crossing timings.
You can look for Ken's document on this topic inside this website. It is a MUST to read for clock designers.
