Aug 15th, 2024, 2:23pm
RSSI (Read 3859 times)
aaron_do
RSSI
Apr 07th, 2008, 5:31am
what kind of accuracy do we normally see in the RSSI? My thinking is that it is difficult to properly define the receivers gain since the LNA and mixer gain an easily vary by a few dB. You can make a very accurate channel fitler and VGA i guess...
thanks,
Aaron
Re: RSSI
Reply #1 - Apr 7th, 2008, 5:52am
aaron_do wrote on Apr 7th, 2008, 5:31am:
thanks,
Aaron
It depends on required input dynamic range and calibration's accuracy. For example, use compensation table determined by calibration procedure.
If you adopt complicated calibration over temperature, supply voltage and input frequency,
accuracy of less than +/-1.5dB is very possible.
Here you need temperature sensor, ADC and EEPROM, etc.
« Last Edit: Apr 7th, 2008, 7:39am by pancho_hideboo »
Re: RSSI
Reply #2 - Apr 7th, 2008, 12:57pm
this is the reason every cell phone on the planet goes thru calibration and storage of some tweak values that are unique to the chip set in the phone. Not able to design around it, or at least it hasnt been done yet.
Jerry
aaron_do
Re: RSSI
Reply #3 - Apr 8th, 2008, 3:31am
thanks for the replies. I took pancho_hideboo's reply to mean automatic calibration during operation. Are you, Jerry, talking about calibration of the chip itself (for instance trimming of resistors)? Also, why would you need such accuracy in the RSSI? I understand you may want to limit the amount of power transmitted to and from the cell phone, but to whay accuracy?
thanks,
Aaron
Re: RSSI
Reply #4 - Apr 8th, 2008, 3:40am
aaron_do wrote on Apr 8th, 2008, 3:31am:
For example, very high accurate transmit power control is needed in CDMA application.
didac
There's a million
ways to see the
things in life
manresa,spain
Re: RSSI
Reply #5 - Apr 8th, 2008, 3:42am
I think that it depends on the system, I don't think that it's needed the same accuracy in a Bluetooth like system(where you use RSSI for power saving) than in a mobile phone system(that control cell handover or cell breathing in the UMTS system).
Hope it helps,
didac
There's a million
ways to see the
things in life
manresa,spain
Re: RSSI
Reply #6 - Apr 8th, 2008, 3:43am
yups... pancho was faster than me writing...
Re: RSSI
Reply #7 - Apr 8th, 2008, 3:24pm
adjustment values are a stored numeric, dumped into flash in a cell phone, not used to trim the chip. Essentially adjustments done in Software (32dbm out is setting 11111 on one phone and 11110 on another kind of thinking)
All phones (CDMA and GSM) need to adjust power output, thats inherent to the system needs.
Accuracy required is within 1-2 db if I remember correctly.
jerry
