Aug 17th, 2024, 3:21pm
High PSR, wide band LDO (Read 1624 times)
jlee
Jan 02nd, 2008, 7:24pm
Dear all,
I want to design a LDO (0.18 um CMOS) and its spec is listed blow:
1. high PSR in wide band (PSR 60 dB, from DC to 1M);
2. output voltage is about 1.5V from vdd of 2.8V;
3. noise requirement: 30 nV/sqrt(Hz) @1 kHz
Is there any paper on this design issue you guys can suggest, or would you like to give me some design guidelines?
Thanks Cheesy
Jason
