Aug 16th, 2024, 1:25pm
Function 'ln' is undefinded or is used recursively (Read 2442 times)
jimwest
Jan 05th, 2008, 1:07am
Hi Folks,
   I met with the following error:"Function 'ln' is undefinded or is used recursively".
And the ln function is used in the model file.
What should I do to fix such bug?
Kindest Regards,
Jim
Re: Function 'ln' is undefinded or is used recursi
Reply #1 - Jan 7th, 2008, 3:19am
You could try replacing "ln" with "log"
Many languages (C, matlab) use "log" for the natural log, and log10 for base10.  Verilog-A is one of the few exceptions that use "ln" for natural log (and "log" is base10).  You should probably check that log gives you the natural log in that simulator's model file language -- the lazy man's approach is to check that "log10" is defined, and assume that implies that "log" is natural log.
