Sep 18th, 2024, 11:20am
derive the transfer function from fully-diff cir. (Read 2560 times)
trashbox
Jan 07th, 2008, 1:17am
I am studying a fully-diff circuit and wanna derive the transfer function from the attached circuit, would you please give me any hints or formulas? Thanks.
Berti
Re: derive the transfer function from fully-diff c
Reply #1 - Jan 7th, 2008, 11:55pm
hmmm, just use nodal analysis. You will get a system of equations which you can solve for
the output (voutp-voutm) and divide by the input (vinp-vinm) in order to obtain the transfer
function.
trashbox
Reply #2 - Jan 10th, 2008, 1:46am
Hi Berti
Thanks. I have solved  this problem.
HdrChopper
Reply #3 - Jan 14th, 2008, 12:10pm
Hi
You can easily derive it by finding using thevenin equivalent circuits. You can use the concept of hemi-circuit, based on the fact you are analyzing a fully diff (purely symmetrical circuit).
If you split the input circuit (Z1/Z3/Z1), you'll get a simple resistor divider equal to Z3/2÷(Z3/2+Z1). That is the input impedance of your input voltage source.
Z2 does not play a role in the transfer function assuming the op amp's input impedance is >> Z2.
From this you get H=-(Z4*(Z3/2 + Z1)) / (Z3/2)
Hope this helps
Tosei
Keep it simple
