Jul 16th, 2024, 10:25pm
no connection module found!! (Read 4066 times)
shirin_br
The Netherlands
Jan 16th, 2008, 5:03am
I am making a behavioural model of my bandgap circuit in Verilog-AMS. There are some digital pins in my schematic which are connected to dc voltage sources in test bench.
The problem occures when I want to simulate the circuit using hierarchy editor of Cadence. I am given error for all the digital pins as:
"No connection module found:Need an input port of continuous discipline electrical, and an output port of discrete discipline logic".
Would you please guide me how I can define this discipline and connect these two?
Thank you so much.
rajdeep
UK
Re: no connection module found!!
Reply #1 - Jan 16th, 2008, 6:16am
What simulator you are using? You have to use AMS Designer.
I'm attaching a pdf that I found useful. This should help you. It
has all the steps well illustrated.
