Jul 18th, 2024, 11:30am
help: rf peak detector (Read 2151 times)
776ft
Jan 16th, 2008, 9:28pm
can someone help me with the rf peak detector?
what architecture can i use if i what to design a rf peak detector which is desired to work up to 750MHz in the rf transceiver?
thank you for view and help
aboco
Re: help: rf peak detector
Reply #1 - Jan 17th, 2008, 4:26pm
There are many topologies for peak detector like diode detectors, logarithmic detectors, true logarithmic detector,...
If you google "logarithmic detector". you are sure to have thousands answer, some of them are even in detail.
