Jul 16th, 2024, 11:33pm
QVCO test buffer match (Read 2348 times)
yhq0413
Jan 16th, 2008, 10:57pm
I  designed a QVCO, the frequency is 4G,now I need a test buffer to evaluate it
Does the test buffer need to match 50Ω? I know the test buffer for LNA must match 50Ω?I think the QVCO test buffer need not,but I am not sure.
Does the buffer that does not match 50Ω affect the phase noise and other performances?
Stefan
Re: QVCO test buffer match
Reply #1 - Jan 17th, 2008, 12:21am
How do you want to measure it and WHAT do you want to measure ?
For amplitude performances (gain, swing, etc.) a matching to your measurement equipment is important,
for time measurements (frequency, PN,etc.) it's unimportant as long as you've got a sufficient output swing and no reflections ...
(That should answer your question.)
View Profile 16731287   IP Logged
yhq0413
Reply #2 - Jan 17th, 2008, 2:39am
“no reflections” means match,but you say  match is unimportant,why?
