Jul 17th, 2024, 1:39am
SpectreRF simulate VCO phase noise with divider (Read 5182 times)
neoflash
Mixed-Signal
Designer
Jan 17th, 2008, 6:51am
Since I failed to get reasonable result, from EldoRF, for a cascaded VCO and divider, I turned to spectreRF.
I'm simulating a 5G VCO with a cascaded divider-by-4. I'm probing phase noise at the output of divider.
When I setup the beat frequency as 5G and put probe at VCO output, the pss analysis can not converge. However, when I put the probe at divider output and set beat frequency as 1.25G, the simulation converged with some warning.
I'm not sure whether it is the correct setup. Since spectreRF is more used among people, hope i can get some help. Thanks.
Stefan
Re: SpectreRF simulate VCO phase noise with divide
Reply #1 - Jan 17th, 2008, 6:53am
Put probe output on vco but set beat frequency to 5G / 4 = 1.25G
Slowest frequency in circuit should determine you period for the PSS.
View Profile 16731287   IP Logged
neoflash
Mixed-Signal
Designer
Reply #2 - Jan 18th, 2008, 1:52am
Yes, thanks.
I found the results are different if I put probe at divider output.
