Jul 17th, 2024, 1:25am
PAC and PSS (Read 3024 times)
aaron_do
PAC and PSS
Jan 18th, 2008, 12:59am
i'm trying to solve a problem with my new PDK, but first I need to verify that there is a problem.
I'm running a PSS and PAC analysis on a simple common source amplifier (one mosfet and a resistor). I input one tone in the PSS analysis at 2.4 GHz. I set the PAC frequency to 2.401 GHz (note that i remembered to set the pac magnitude on my input port to equal the PSS amplitude).
ok. Next I plot the voltage gain on the PSS form and found the answer to be +13 dB. Then I plot the voltage gain of the "0" harmonic (2.401 GHz) on the PAC form. I found the answer to be -11 dB.
please set my mind at ease and verify that the answer is wrong.
Aaron
P.S my mixer circuit has -200 dB gain on the PXF analysis instead of +15 dB so i'm quite convinced there's something wrong.
Re: PAC and PSS
Reply #1 - Jan 18th, 2008, 1:40am
Normally one sets pacmag to 1 to facilitate the computation of gain. Did you account for the fact that you did not?
Oh, and it is the "0 sideband" not "0 harmonic". A harmonic is a spectral component at an integer multiple of the fundamental frequency. A sideband a spectral component that is offset from the analysis frequency by a multiple of the fundamental frequency. So the harmonics are found at ...
0 dc
1 2.4GHz
2 4.8GHz
3 7.2GHz
The analysis frequency is 2.401GHz, and so the sidebands are found at ...
-2 -2.399G
-1 1M
0 2.401GHz
1 4.801G
2 7.201GHz
I'm not sure why PXF is not working for you. Perhaps you can give us more details on your set up.
aaron_do
Re: PAC and PSS
Reply #2 - Jan 20th, 2008, 5:17pm
ok thanks.
I did take into account that pacmag<>1. I am using a new PDK, so I suspect it has problems. Maybe some kind of handshaking routine between the PDK and the simulator? I don't really know the inner workings...Also since it only seems to be analyses associated with PSS (but not PSS itself), could it be a compatibility issue with spectreRF?
Aaron
Re: PAC and PSS
Reply #3 - Jan 20th, 2008, 5:52pm
The "handshaking" is simply the netlist. Nothing from the PDK is RF related (except the analyses themselves).
