kevinm
ireland
Hi, I've a question about simulating divider phase noise: After running a pnoise analysis (noise type =jitter) I can plot the noise voltage PSD at the threshold crossing time pow(getData("out" ?result "pnoise_pmjitter") 2) Is this SSB noise? Or do I need to divide this noise by a factor of 2 before I can calculate the divider's SSB phase noise using equations (1) and (5) in the doc "Simulating the Phase noise Contribution of the divider in a phase lock loop" thanks for your help, Kevin.
