Aug 17th, 2024, 10:21am
SPECTRE : saving and recovering checkpoints ? (Read 2722 times)
olifant
Jan 17th, 2008, 6:01am
Although the SPECTRE simulator manual states that it is possible save checkpoints (using the +checkpoint command line option), in order to recover them later on (using the +recover command line option), this does not seem to work.  The checkpoint gets saved alright (input.scs.tran.ckpt), but when I try to restore it, the simulator locks up.  The output log shows the following (see below) and then freezes.  I'm trying to use the checkpoints since I am running simulations which need a long time to converge: I tried to speed this up by using initial conditions ("readic=spectre.fc" in the netlist, where spectre.fc is the file containing the initial conditions at the end of the previous simulation), but this does not give very accurate results, even if I tie up the tolerances.  Any suggestions ?  Thanks in advance for the help.
Transient Analysis `tran': time = (0 s -> 1 ms)
Recovering from checkpoint file input.scs.tran.ckpt
Restarting at time 378.059 us.
