Jul 16th, 2024, 11:39am
Modeling DDS/DAC modulator (Read 9048 times)
Faisal
Jan 27th, 2008, 10:13am
I am trying to model a DDS/DAC and quadrature modulator in Spectre-RF? Is it possible to model this in Spectre-RF?
My concern is that DDS/DAC requires transient simulations and modulator will require Spectre-RF?
Any ideas on how to do this ?
Stefan
Re: Modeling DDS/DAC modulator
Reply #1 - Jan 27th, 2008, 12:02pm
If you write good enough behavioral models, the modulator won't require spectreRF (however, some measurements might be faster with spectre RF).
View Profile 16731287   IP Logged
Faisal
Reply #2 - Jan 30th, 2008, 1:25pm
Hi Stefan,
Thanks for the response. What do you think would be a better tool for system level exploration? Matlab, Spectre, ADS.. any suggestions?
Stefan
Reply #3 - Jan 30th, 2008, 3:26pm
That strongly depends on what you're trying to do.
If you want system simulations that can be simulated together with transistor level parts - use VerilogAMS.
For pure system level simulations with much IP reuse like modulated signals and so on - use Matlab.
I personally dislike ADS, but that's my own oppinion.
It all depends on how good you are writing models and how much control over your model's behaiour you desire...
Faisal
Reply #4 - Feb 6th, 2008, 6:52am
Hi Stefan,
Thanks once again !!
I would also prefer using SpectreRF, I can model my modulator quite easily. I have the following issues
1) How to model an accumulator in SpectreRF .. I need a go-around for the hidden state problem,
2) I am not clear if we can mix Verilog-AMS with SpectreRF?
Stefan
Reply #5 - Feb 6th, 2008, 6:56am
spectreRF is not a language, it's a simulator.
"Hidden state" is  a phenomenom that occurs during periodic steady state analysis.
An accumulator behaves like a capacity ... that should be no problem to model.
However I thought we were talking about MIXED SIGNAL simulations.
And no, you can't use the Verilog-AMS language with the spectreRF simulator. (just verilogA with respect to hidden states)
Faisal
Reply #6 - Feb 6th, 2008, 7:19am
Yes you are right about SpectreRF that its a simulator : I use the language/Simulator interchangeably, this is misleading.... .
If I say count = count + 1 in VerilogA and run PSS analysis in SpectreRF, I sometimes get an error from the SpectreRF complaining about the hidden state. For some modules that I have from Cadence rflib, I see similar modeling.. but they dont run into problems
Faisal
Reply #7 - Feb 6th, 2008, 7:27am
module try(out_sin);
output out_sin;
electrical out_sin;
real count, period, cos_angle;
analog begin
 @(initial_step("static") or initial_step("pss") ) begin
   count = 0;
   period = 1 / 10M ;
@(timer(period/10, period)) begin
 count = count + 1;
V(out_sin) <+ cos(2*3.14*1M*count);
Reply #8 - Feb 12th, 2008, 6:41am
Faisal wrote on Feb 6th, 2008, 7:19am:
I think Cadence provides some attribute ("instrumentation_module" ?) to disable the warning.
Frank Wiedmann
Munich, Germany
Reply #9 - Feb 12th, 2008, 7:09am
Geoffrey_Coram wrote on Feb 12th, 2008, 6:41am:
It's (* instrument_module *) in front of the module name, see http://sourcelink.cadence.com/docs/db/kdb/2005/July/11187476.html.
Faisal
Reply #10 - Mar 3rd, 2008, 1:40pm
Thank you Geoffrey and Frank for your replies. It was helpful in understanding
