Aug 17th, 2024, 1:12pm
Pages: 1 2
cmos down conversion mixer (Read 11813 times)
udaykumarchintala
ahmedabad
Feb 12th, 2008, 10:36am
Hii,
    I want know the design methodology for the down conversion mixers............help me.........
Stefan
Re: cmos down conversion mixer
Reply #1 - Feb 12th, 2008, 11:06am
There are plenty of books available.
Check for Lee, Razavi, Gray, Johns, Baker ...
Maybe also check for the phrases please, kind or other complimentary flowers of speech Smiley
Kind Regards,
Stefan
View Profile 16731287   IP Logged
udaykumarchintala
ahmedabad
Reply #2 - Feb 17th, 2008, 5:34am
hii,
    What is the effect of matching circuits on the performance of the mixer?????Is it compulsory to design them??????????
thanks in advance,
uday
Stefan
Reply #3 - Feb 18th, 2008, 12:18am
That strongly depends on the rest of your design. A mixer not capable of driving the load is useless. However you can simulate the mixer with any matching around it that you desire, whether that's a "real world simulation" is another question ...
btw. check your "?"-key, I guess it's stuck someway.
Stefan
udaykumarchintala
ahmedabad
Reply #4 - Feb 25th, 2008, 5:08am
   In principle for a Mixer the LO signal is a square wave,but in most of the papers I have gone through they have carried out the simulations by taking the sine wave as a LO signal.Why?What is the difference?Do we get the desired output in both the cases?
Thanks in advance
Uday
Stefan
Reply #5 - Feb 25th, 2008, 5:10am
Sine-Signals do work better with simulations like HB or alike ...
It's not THAT realistic then, but the higher order harmonics are often of no interest, because they are filtered sufficiently.
didac
There's a million
ways to see the
things in life
manresa,spain
Reply #6 - Feb 25th, 2008, 12:23pm
You should always make a design as close to the reality as possible, in this case the question is:which kind of signal will deliver the oscillator to the mixer? At very high frequencies it's not as easy as it seems to generate a good square wave, but if you consider the phase-noise requirements(to avoid reciprocal mixing) tunned oscillators generating a sine wave usually are more suitable to achieve the target specifications.
udaykumarchintala
ahmedabad
Reply #7 - Feb 27th, 2008, 11:23am
hii,
   How do we design a mixer for a desired gain,generally in a cascode the gain is gmRl.but in case of mixer how do we design for the same at a high frequency and the output frequency is also different.How to get a such a large gain at GHz ranges?
Thanks in advance
uday
Reply #8 - Feb 28th, 2008, 4:46pm
Mixers freqeuently dont have that much gain (12db at an absolute max? YMMV)  :-/but the gain is in around them, pre and post.
Jerry
udaykumarchintala
ahmedabad
Reply #9 - Mar 1st, 2008, 1:27pm
          In some of the previous designed mixers they used folded cascode structure,
  the only difference between folded cascode and these mixers is that a switching
  transistor .....is it right?Is the design procedure is same?
 Thanks in advance
didac
There's a million
ways to see the
things in life
manresa,spain
Reply #10 - Mar 2nd, 2008, 4:03am
Folded mixers are useful if your concern is voltage headroom since you don't have all the elements stacked one over the other. But beeing a different circuit topology brings to other design trade-offs like:between Vdd and the transconductor is a current source, a resistor(both lower the headroom),an inductor(if it's not a bondwire the finite Q could be losses),a LC tank tunned at fo?. Also the switching pair is a PMOS so it should be taken into account it's suitability in function of your operating frequency and technology.
Hope it helps,
udaykumarchintala
ahmedabad
Reply #11 - Mar 2nd, 2008, 8:53am
     Thanks for your reply.....
     what my question was the design procedure of folded cascode mixer is same as the folded cascode except the switching transistor?
thanks...
didac
There's a million
ways to see the
things in life
manresa,spain
Reply #12 - Mar 2nd, 2008, 9:11am
I apologize if my answer was unclear. The design procedure it's the same for sizing(gm,rload,bias,LO amplitude), but my point was that beeing a completely different topology you should consider the specific issues of the circuit.
udaykumarchintala
ahmedabad
Reply #13 - Mar 2nd, 2008, 9:36am
   thanks a lot.......
   Can I find any tutorial for this design procedure?
Thanks.......
Uday
didac
There's a million
ways to see the
things in life
manresa,spain
Reply #14 - Mar 2nd, 2008, 10:50am
You can check:
http://weble.upc.es/rfcs/Material/mixer_chandra.pdf
http://www.zen118213.zen.co.uk/RFIC_Circuits_Files/MOS_Gilbert_Cell_Mixer.pdf
Or the chapter of Mixers of Thomas Lee Book:"The Design of CMOS RFIC".
Hope it helps,
Pages: 1 2
