udaykumarchintala
ahmedabad
Hi, I have designed a folded cascode mixer at 2.4GHz RF and LO is at 2.3GHz,I'm getting 1 dB compression point as 0.56dBm,for calculating IIP3 I have given two tones as 2.401G and 2.4G , while plotting the curves, both the fundamental and third order components are intersecting what could be the problem?I have not designed the matching circuits......will it cause this?
Thanks in advance....
