Aug 15th, 2024, 1:31pm
EKV model (Read 7300 times)
udaykumarchintala
ahmedabad
EKV model
Feb 25th, 2008, 6:10am
Hii,
   Can I get EKV model .18um technology file anywhere?
thanks in advance
uday
Berti
Re: EKV model
Reply #1 - Feb 25th, 2008, 6:42am
I think there is tool available with translates a BSIM to a EKV-model.
But it is not for free.....
Check the EKV official website.
modelg
Re: EKV model
Reply #2 - Feb 27th, 2008, 1:44am
Hi, is there a tool to convert PSP to BSIM or vice-versa ? Thanks..
Thanks!
Re: EKV model
Reply #3 - Mar 12th, 2008, 11:59am
I've never heard of one.  The models are very different (surface-potential vs threshold-voltage).
duckila
Strasbourg, France
Re: EKV model
Reply #4 - Mar 12th, 2008, 4:06pm
udaykumarchintala wrote on Feb 25th, 2008, 6:10am:
Hii,
thanks in advance
uday
maybe u can find something on this site
http://legwww.epfl.ch/ekv/model.html
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: EKV model
Reply #5 - Mar 19th, 2008, 1:58pm
There is no tool that can convert from one transistor model to another - at least not from the same family. Even if it did exist there would be little use for it as the accumulation of errors in fitting the one model's parameters to the results of another one's fit to measured curves would render the results with too much error. Either a foundry sticks to one model or it characterizes the models always from (the same) set of measured curves.
If you want to do this anyway, the home-made recipe is to retrieve the characterization procedures for the model you want to fit, translate these into simulations against the curves from the reference model and run a circuit optimizer to perform the fitting. For a very rainy Friday afternoon, I guess.
Cheers,
Marq
