Upemba,
There is an application note in the Modeling section that describes the
required setup for Monte Carlo simulation.
http://www.designers-guide.org/Modeling/montecarlo.pdfWhen you perform Monte Carlo simulations, there are process variations, inter-die
variations, and mismatch, intra-die variations. You need to describe the mismatch
statistics in order to perform mismatch analysis. You also need to use in-line subckts,
see the paper for more details.
