jimwest
Hi folks, I am stucked while installing the pdk in IC610. Is IC610 compatible with the pdk which is not an open access one? I searched the menu in CIW and found out there is an OA translator. But I failed to open the library by applying the translator. Is there any solution?
Kindest Regards,
Jim
