May 20th, 2024, 4:08am
Pages: 1 2
spectre transient noise (Read 33202 times)
panditabupesh
Toronto
Feb 27th, 2008, 6:24pm
Hi
I have been trying transient noise simulation on a switched capacitor filter. Without noise enabled, I was getting an SNR of greater than 90 db, but with noise enabled the SNR dropped to 42 dB.
The output power spectral density shows a flicker noise kind of noise floor. I forced the flicker noise parameters in the models to zero, but despite that I am not seeing any improvement in the SNR and also the output PSD continues to shown an 1/f shape. I am simulating an audio circuit.
Any insights on what is going on would be helpful.
Bupesh
Stefan
Re: spectre transient noise
Reply #1 - Feb 28th, 2008, 2:40am
Maybe you should check the generation of the clock for the switches ...
You can use the simulator to check for the noise sources that distribute to the output. What does it say ?
View Profile 16731287   IP Logged
panditabupesh
Toronto
Reply #2 - Feb 28th, 2008, 5:57am
Hi
Today I tried with noisefmin greater than noisefmax (basically, to eliminate flicker noise contribution) and the SNR improved to 70 dB (about 30 dB improvement).  With flicker noise parameters in the models zero, I can not understand how spectre is generating flicker noise.  I generated a report, in Ocean,  on the models and confirmed that the flicker noise parameters are zero.
The clocks are  from an ideal non-overlapping clock generator. Also, how can I use the simulator to tell me about the contribution of each device to the output noise.
Bupesh
HdrChopper
Reply #3 - Feb 28th, 2008, 4:52pm
A couple of quick questions:  is the SC circuit an integrator?, what do you have at the input of the SC filter?
Tosei
Keep it simple
Reply #4 - Feb 28th, 2008, 9:42pm
Have you considered using SpectreRF's PNoise analysis?
panditabupesh
Toronto
Reply #5 - Feb 29th, 2008, 5:58am
Hello
Yes the circuit is an integrator, and the input is an ideal sine wave.
Ken, with flicker noise parameters made zero (BSIM4 parameters with fnoimod=1, and all flicker noise parameters, noia noib noic including kf made zero), pnoise, unlike transient noise, shows flicker noise disappearing.
Bupesh
HdrChopper
Reply #6 - Feb 29th, 2008, 7:12am
I'm not completely sure about this but, what if you have a white noise component at the input of your SC integrator? My point is that the white noise, once integrated, looks like flicker noise at the output of any integrator (I guess). What source of white noise do you have at the very input of your integrator? May be the input switches?. An easy test would be just to put ideal switches at the input just to see if your flicker like output noise gets reduced in the transient sim....
Tosei
Keep it simple
panditabupesh
Toronto
Reply #7 - Feb 29th, 2008, 7:59am
Hello Tosei
The idea that integrator is coloring the white noise is really possible, and I am planning to explore it further. But, then why should making noisefmin greater than noisefmax impact the output noise psd.
Bupesh
panditabupesh
Toronto
Reply #8 - Feb 29th, 2008, 8:49am
Hello
Perhaps, I am confused about one more thing:
For noisefmin = noisefmax condition, does spectre use the thermal noise parameters of the devices (or just the 4kTBR equation for the resistors)? The transient noise application note says that, "spectral noise density will be zero above noisefmax, constant below noisefmin, and will follow the device noise equation in between".
How does spectre decide the noise magnitude below noisefmin?
Bupesh
Reply #9 - Feb 29th, 2008, 2:04pm
Trying to perform flicker noise simulations with transient noise is expensive and error prone. So, given that SpectreRF is giving you the expected results, why are you bothering with transient noise?
panditabupesh
Toronto
Reply #10 - Feb 29th, 2008, 2:54pm
Ken, the idea was to find SNR and harmonic distortion etc., under real signal conditions.
Bupesh
safwatonline
Reply #11 - Mar 13th, 2008, 7:28am
i noticed that i don't have the transient noise in my cadence version, what is the version u r using?
kDaniu
Reply #12 - Apr 3rd, 2008, 6:22pm
does anybody How to use the same spectre advantages "transient noise" in hspice (I mean auto generation (on the fly) the noise during transient simulation) ?
right now to get the noise I just put the artificial noise using pwlf component, but that is not comfort in the case of long time simulations
thanks
Dan
Reply #13 - Apr 4th, 2008, 7:22am
I've heard that Eldo has transient noise, but I'm not aware that HSpice does (yet?).
kDaniu
Reply #14 - Apr 4th, 2008, 4:22pm
I know that such possibility is absent.
but I'm asked about any another mechanizm to get it in scheme (at least on the imporant places)..
maybe present some way to auto generation (on the fly) the noise during transient simulation f.e. by using Monte Carlo possibilities (right now this way do not help me) etc... Sad
thanks,
Dan
Pages: 1 2
