achim.graupner
Hi there,
well the most simplest solution is using the final operating point. In Cadence ADE this option is "hided" is in the Setup->Simulation->Transient->Option.
As far as I remember you need to do an DC op before the noise analysis, as in noise analysis nodeset has been or still is not supported.
To change the analysis order (to have dc before noise) in ADE it is Setup->Environment->Simulation Order, just use spectre syntax there.
Hope that helps, Regards,Achim
