Jul 16th, 2024, 11:35am
how to simulate noise matching for LNA in spectre? (Read 2670 times)
icguy
Seoul Korea
Mar 11th, 2008, 7:39am
HI:
  I can simulate the equivalent  noise impedance in ADS  to obtain the difference between the noise impedance and the optimal noise impedance,which is a very useful function.But in spectre, i only find the simulation-NF and NFmin.I don't know which component and how much to adjust to reduce the NF.
Hope to get explanation soon Cheesy
The trouble with random processes is that they are random
Re: how to simulate noise matching for LNA in spec
Reply #1 - Mar 11th, 2008, 7:58am
GammaOpt is available.
If my memory is correct, this is defined as variable of Gmin.
« Last Edit: Mar 11th, 2008, 9:51am by pancho_hideboo »
icguy
Seoul Korea
Reply #2 - Mar 11th, 2008, 6:48pm
As i know, Gamma is relative with channel length.I have simulate Gamma through Common-gate LNA whose Noise Factor is 1+Gamma.The simulate results is approximately  from 0.7 to 0.9,not more than 1,which is very similar with the theory in short channel.
Sorry,I don't understand what is your meaning,Could you just explain that again in detail,thx.
I want to obtain the equivalent noise impedance Zopt through SpectreRF.
I am looking forward to a favorable reply at your earliest convenience.
My eamil: icguy@yahoo.cn
Reference:
T.K.Nguyen, C.H.Kim,G. J. Ihm,M. S.Yang, and S. G. Lee, “CMOS
low-noise amplifier design optimization tehcniques,” IEEE Trans. Mi-
crow. Theory Tech., vol. 52, no. 5, pp. 1433–1442, May 2004.
pancho_hideboo wrote on Mar 11th, 2008, 7:58am:
Reply #3 - Mar 11th, 2008, 10:51pm
You are misunderstanding.
"Gamma" I mean is reflection coefficient.
So maybe "GammaOpt" is refered as "Sopt" in Agilent ADS.
See attached figure.
In cadence, "GammaOpt" is available as "Gmin" in direct plot menu.
In results browser, this is defined as Yopt("Gopt" and "Bopt") alternatively.
Yopt is the source admittance that gives the minimal noise factor Fmin (corresponding to the source reflection coefficient Gamma opt)
and Rn is the equivalent noise resistance. Finally, NFmin, the minimum noise figure, is Fmin, the minimum noise factor, in dB.
See pp.1560-1561 of $CDS_INST_DIR/doc/spectreRF/spectreRF.pdf
« Last Edit: Mar 12th, 2008, 7:50am by pancho_hideboo »
Reply #4 - Mar 11th, 2008, 10:52pm
This is ADS output data for SP analysis.
icguy
Seoul Korea
Reply #5 - Mar 12th, 2008, 1:44am
Thank you very much! Please accept my thanks for your support.
By the way,my"SpectreRF User Guide" is Product Version 5.0 published in September 2003.
Could you send the lastest version to me?
I cann‘t express my excitement and my gratitude much more!
Reply #6 - Mar 12th, 2008, 2:04am
I can't distribute product manual freely.
And you can find necessary information
in your "SpectreRF User Guide" of Product Version 5.0 published in September 2003.
« Last Edit: Mar 12th, 2008, 3:14am by pancho_hideboo »
icguy
Seoul Korea
Reply #7 - Mar 12th, 2008, 5:26pm
Thank you all the same Cheesy
