Aug 17th, 2024, 11:13am
Switched tuning LC oscillators (Read 4090 times)
neoflash
Mixed-Signal
Designer
Mar 19th, 2008, 5:24am
Normally, people use MIM or finger metal capacitor for high linearity. Anyone ever see paper use varactor or moscap as switched tuning capacitor array?
Pls suggest reference, thanks.
ACWWong
Oxford, UK
Re: Switched tuning LC oscillators
Reply #1 - Mar 19th, 2008, 6:05am
lots of people use moscap for switching.... better Q can be acheived (depending on circumstances of course) using MOS rather than a switch in series with a MIM. Nearly all papers i've seen of late for CMOS switched LC VCO use MOS switched caps.
If you google it i'm sure you'll find loads of papers, but i do like this earlier example from RFIC2000:
"A LOW PHASE NOISE MONOLITHIC VCO IN SiGe BiCMOS"
Jean-Marc Mourant, Jim Imbornone, and Ted Tewksbury*
http://ieeexplore.ieee.org/iel5/6896/18556/00854418.pdf?isnumber=18556&prod=CNF&...
neoflash
Mixed-Signal
Designer
Reply #2 - Mar 19th, 2008, 7:11am
use direct mos cap, controlled by digitally biasing of the backside might suffer big supply noise pushing.
If there is no voltage regulator for the digital control signal, the conversion from power noise to phase noise should be high.
neoflash
Mixed-Signal
Designer
Reply #3 - Mar 19th, 2008, 7:14am
any people ever try put varactor in series with switch, for switched tuning?
jlee
Reply #4 - Mar 23rd, 2008, 7:05pm
Another reference: "Design of wide-band CMOS VCO for multiband wireless LAN application" by N. H. W. Fong.
For varactor/moscap based switch cap, biasing voltage noise (LDO, current biasing) is a big concern. Try PXF simulation, and you will find the flicker noise upconversion gain is normally increased by 10dB.
Actually, well designed mimcap based switch cap has little effect on phase noise and its cmax/cmin (>4) is really higher than varactor based switch cap (<3). Q is not always the criterion for phase noise performance. Cheesy
Jason
neoflash
Mixed-Signal
Designer
Reply #5 - Mar 25th, 2008, 7:29am
The binary biased varactor always make me surprised. Without good regulator, the supply noise can raise the noise floor to absurd level. However, I often see authors of Jssc using this design without regulator highlighted. Then, I just keeps being surprised.
