Jul 16th, 2024, 12:21pm
charge pump mismatch, reference spur and jitter (Read 2518 times)
keikei
beijing
Mar 27th, 2008, 8:28am
In a charge pump PLL, the charge pump current mismatch causes reference spur in the PLL output spectrum.  Is it possible to FFT the PLL output in a transient simulation by spectre to find the reference spur?  Is the mismatch or the reference spur one of the sources of PLL’s deterministic jitter?
Visjnoe
Re: charge pump mismatch, reference spur and jitte
Reply #1 - Mar 28th, 2008, 2:38am
Dear Keikei,
1. Yes, you can detect the reference spur in the PLL output by taking its FFT.
2. Yes, the reference spur is a source of deterministic jitter, since you now the exact
   cause of the jitter component at this frequency (namely the reference).
Kind Regards
Peter
