Aug 15th, 2024, 10:34am
pll simulation using phase domain models (Read 178 times)
rfmems
Mar 31st, 2008, 2:03am
I am new to verilog-A simulation of pll. When I read Ken's "Predicting the phase noise and jitter of pll-based frequency synthesizers", in the VCO model
Theta(out)<+2*'M_PI*gain*idt(V(in))
So here the Theta(out) will increase infinitely unless V(in) is zero,  then small signal simulatoin doesnot work, how can I solve this problem?
Another question is, I converted all the simulated block phase noise (dBc/Hz) into "power" by 10^(L/10) and then input them into noise table, is that the right way to do it?
Thanks a lot
chenyan
Re: pll simulation using phase domain models
Reply #1 - Mar 31st, 2008, 7:39am
rfmems wrote on Mar 31st, 2008, 2:03am:
Use "idtmod()".
Maybe it works.
« Last Edit: Mar 31st, 2008, 11:59am by pancho_hideboo »
rfmems
Reply #2 - Apr 1st, 2008, 12:10am
Thanks a lot! pancho_hideboo.
Yes, I think idtmod will work, but we have to do pss+pnoise right? And we will use again 2 frequencies, one reference and one vco.
But Ken mentioned with phase domain models, using only small signal simulation like AC or noise will do. Would there be an alternative way to do so?
Reply #3 - Apr 1st, 2008, 12:41am
rfmems wrote on Apr 1st, 2008, 12:10am:
Although I don't know what you like to do, the following might be helpful.
$CDS_INST_DIR/tools/dfII/samples/artist/rfLib/osc
Do you understand phase model and voltage model ?
