Jul 16th, 2024, 4:50pm
cmos down conversion mixer (Read 11842 times)
udaykumarchintala
ahmedabad
Feb 11th, 2008, 10:06am
hii.
     How to generate square wave  of desired frequency in RF spectre for simulating the mixer????
Re: cmos down conversion mixer
Reply #1 - Feb 11th, 2008, 5:10pm
With a pulse source, just like you would in transient analysis.
udaykumarchintala
ahmedabad
Reply #2 - Feb 12th, 2008, 9:25am
hiii,
     By using a pulse source I am unable to generate the required frequencies ,it is asking for a particular time period..............
didac
There's a million
ways to see the
things in life
manresa,spain
Reply #3 - Feb 12th, 2008, 9:52am
Time-frequency duality. f=1/period,period=1/f
Hope it helps,
udaykumarchintala
ahmedabad
Reply #4 - Feb 14th, 2008, 1:11am
  For example if I want to generate a 2.3 GHz LO square signal, can I generate it by giving a  time period of
.434 n sec for the pulse source????????Will it work?????
Reply #5 - Feb 14th, 2008, 3:56pm
Set the period to 1/2.3GHz. The width and levels of the pulses can be adjusted with other parameters. See "spectre -h vsource" for more information.
udaykumarchintala
ahmedabad
Reply #6 - Feb 26th, 2008, 11:47am
Hi.....
     How to calculate the extrapolation points while measuring the 1dB compression point and IIP3 for the mixer in spectre........
Thanks in advance.......
udaykumarchintala
ahmedabad
Reply #7 - Mar 3rd, 2008, 9:24am
hi,
    I have designed a mixer which has -1.477dBm 1dB compression point,but for the same I am unable to simulate the IIP3, RF frequncy is 2.4GHz and LO is 2.3GHz for this
mixer...please help......
Thanks in advance
uday
udaykumarchintala
ahmedabad
Reply #8 - Mar 3rd, 2008, 12:15pm
   How to find out the LO-RF isolation in cadence spectre for a mixer?
uday
udaykumarchintala
ahmedabad
Reply #9 - Mar 4th, 2008, 11:06am
    I have designed a mixer with RF =2.4GHz,LO=2.3GHz as we know the IF is at 100MHz.I got 1 dB compression point of -1.47dBm for this,but I am unable to calculate IIP3 for this in the spectre,I have taken the interfer as 2.41GHz ,for this the third order interferers at the output will be at 140MHz and at 90 MHz,while simulating I am unable to give the arry of indices in the PAC analysis in spectre......help me....
khouly
Reply #10 - Mar 24th, 2008, 8:03am
to get the feed through , just plot the spectrum of the node u want , and then find the component and calculate how much attenuation
khouly
udaykumarchintala
ahmedabad
Reply #11 - Mar 25th, 2008, 11:48pm
   expalin me a bit more......if i want to measure the feed through from LO-RF how should I do ?Should I use PSS analysis and plot spectrum at both LO
and RF ports and to see the feed through????
udaykumarchintala
ahmedabad
Reply #12 - Apr 11th, 2008, 11:43am
hii,
    For my mixer I have plotted voltage gain by PSS analysis and conversion gain by PSS/PXF .I am not getting the same value.whay?what is the difference?
Reply #13 - Apr 13th, 2008, 8:06am
udaykumarchintala wrote on Apr 11th, 2008, 11:43am:
    For my mixer I have plotted voltage gain by PSS analysis and conversion gain by PSS/PXF.
Maybe you are using "Direct Plot Menu" to plot Gain. Is this correct ?
Do you understand gain definitions of PSS, PAC, PXF and Pnoise in "Direct Plot Menu".
See the followings.
http://www.designers-guide.org/Forum/YaBB.pl?num=1122952471/5#5
http://www.edaboard.com/viewtopic.php?t=214650&highlight=
You should write down gain definitions for PSS and PXF in "Direct Plot Menu".
Especially you have to study denominator of gain each for PSS and PXF.
