didac
There's a million ways to see the things in life
manresa,spain
Hi, Try to check your process documentation, but I've found several combos depending on the Design kit: 1)pin in pn 2) label with the pin name in the same layer that the metal 3)pin in pn and with the label in the same metal(not pn), also the label should be inside the pn Hope it helps,
