Jul 16th, 2024, 9:04am
Assura LVS unbound pins (Read 3827 times)
vkale
Apr 03rd, 2008, 8:29am
I am working with Assura LVS tool and i have the problem with unbound pins. I make an inverter and I get a message about unbound pins (vdd,gnd,in,out). I use the Layout XL and the layer for the pins is pn.
Is there any useful advice to solve that? Is there any depedence with the Assura version?
didac
There's a million
ways to see the
things in life
manresa,spain
Re: Assura LVS unbound pins
Reply #1 - Apr 3rd, 2008, 10:07am
Try to check your process documentation, but I've found several combos depending on the Design kit:
1)pin in pn
2) label with the pin name in the same layer that the metal
3)pin in pn and with the label in the same metal(not pn), also the label should be inside the pn
Hope it helps,
