holddreams wrote on Apr 3rd, 2008, 7:15pm:Any one has generated IBIS model using Spectre simulator?
Can you give me some suggestions?
I think the IBIS model is just like a look up table. The simulation result from your simulation with spectre will be changed to IBIS format.
There is a small tool from intel can do the format conversion.
I forget the tool's name. You could search it.
Good luck!~
-icsoul
