Jul 18th, 2024, 10:29am
How to generate IBIS model using spectre simulator (Read 4447 times)
holddreams
Apr 03rd, 2008, 7:15pm
Any one has generated IBIS model using Spectre simulator?
Can you give me some suggestions?
icsoul
Re: How to generate IBIS model using spectre simul
Reply #1 - May 29th, 2008, 6:39am
holddreams wrote on Apr 3rd, 2008, 7:15pm:
I think the IBIS model is just like a look up table.  The simulation result from your simulation with spectre will be changed to IBIS format.
There is a small tool from intel can do the format conversion.
I forget  the tool's name. You could search it.
Good luck!~
 -icsoul
