Aug 17th, 2024, 12:21pm
SNR: AC VERSUS TRAN (Read 2162 times)
superpfff
SNR: AC VERSUS TRAN
Apr 07th, 2008, 3:53am
Hi.
I designed a CTIA (Capacitance TransImpedance Amplifier) based on a Common source (CS) amplifier using cascoded devices. It is a classical cascoded common source biased by a low voltage current mirror. Theory shows:
    From the input referred noise perspective, cascoded devices show the the same performance than a simple common source amplifier
    Moreover, for the output, it's been proved that the SNR at the output gets better
The weakness, compared to the classical CS, is the voltage excursion. We lose 2 times VDSsat.  It means that the capacitance will get less "charges" with the cascoded device than with the simple CS. To me, it implies that SNR has been damaged because of the lack of excursion.
What's your opinion? Some tips to put that on equations?
HdrChopper
Re: SNR: AC VERSUS TRAN
Reply #1 - Apr 7th, 2008, 7:15pm
I think you are just limiting the output dynamic range while improving (or at least keeping) the SNR. Assuming your cascode does not add any noise, then both the input noise and signal will get amplified by the same number (disregarding frequency domain considerations) so SNR is the same. It is just you can accomodate less signal (and less noise) with the cascoded version.
Hope this helps
Tosei
Keep it simple
superpfff
Reply #2 - Apr 8th, 2008, 7:13am
thechopper wrote on Apr 7th, 2008, 7:15pm:
Hope this helps
Tosei
Hi Tosei. thx for the answer.
Input signal and input noise aren't amplified by the same number in cascoded devices. Because of quadratic relationships, noise progression is of squareroot type. So that at the end, cascoded devices improves SNR.
So my question is: is the output dynamic range improves or not the SNR? I can't prove it, but it seems to me that, in large signal,  the more dynamic, you have the better the SNR is.
