Berti,
This is probably not the direction you are looking for and is more of a philosophical question. However, it if the design is so sensitive to noise, does integration make sense? I don't understand the economics driving your project, but would System in Package, SiP, be a better approach than integration for this level of performance? SiP would give you an opportunity to use passives to reduce noise, etc. that is difficult to do in integrated designs.
